offbeatbryce
I've been googling for an hour and can't find a 4k pocket camera that shoots at 60fps. Is there one that exists?
I do not think there is a 4k60p pocket camera. The GH5 is probably the smallest camera out there that shoots in 4k60p. That is a lot of data flying by!
The videos could be mixed but the 30p video will stand out a bit with a little motion difference. This may be lessened if it is a stationary shot but any subject movement will have a different cadence. Slo motion would actually be better for mixing since the 60p look will be broken although the 60p footage will let you slow down more before falling apart.
This is easy to test. Shoot some different stuff in HD and mix it up. See what you like or dislike.
What is your final output framerate?
Only you can decide what quality works for your projects. Remember motion blur is a function of the shutter speed, not the framerate. 60p and 30p often use 1/60th for the shutter and 24p uses 1/48th or 1/50th.
Yes, 60p is best for live stuff and 24p is the standard for everything else. 30p is in the middle and not used quite as often but still good for internet viewing.
