Steve Castle
My understanding of the AF100 is that it doesn't line skip, it pixel bins. Which allows you to use that lost area.
Although, I hope you noted that I said "Size isn't all that matters" which you go on to explain the other possibilities for extended DR using back illumination. I absolutely agree that it is a factor, but just one factor.
I also don't see the photosites as massive in the Arri Alexa, they are around 8.25um maximum, whereas the 5Dm2 is 6.4um square. But, look at the Red MX sensor, it has 5.4um square, smaller than the 5Dm2 (and I am talking about using the 5D in photo mode, not movie mode) and it has around 13 stops (not including the HDRx stuff). That's pretty amazing. Granted, DR does not have an industry standard as you say.
There is A LOT of magic that goes into making a sensor. Basing the sensitivity just on the sensor size and resolution is NOT an indication of what you are going to get. So much depends on other factors of the design, including the AD conversion, noise in CMOS circuits, special methodologies in the CMOS technology.
I mean, let's even take it a step further, the M sensor has less dynamic range than the MX sensor, and they are the same exact size. Point being, trying to judge how this camera from JVC is going to behave at 4K just isn't possible till you know everything they are doing. They may be employing methods, just as red has proven, that can allow higher resolutions and higher DR by following different methodologies, which may in fact, not work as well at a larger size. Don't forget, the larger the active area, the longer it is going to take to drain out the current as well. This might be why Red's read/reset time on the Red is so fast.
The AF100 doesn't pixel-bin, in fact, pixel-binning is very difficult for a rolling shutter CMOS sensor since it needs to capture multiple photosites simultaneously. In the past, pixel-binning has been reserved for CCD sensors with global-shutters that capture the entire frame and are easier to 'bin'. For CMOS sensors to do pixel-binning you need to use summation techniques that require additional logic and are significantly more complex. However, the AF100 does use video-centric OLPF that does minimizes the aliasing issues associates with dSLR sensors.
As far as reading into claims of how many 'stops' a sensor has in DR a lot of that can be deceptive, if not down-right dishonest. You'll get different results based on what test you do; Stouffer, DSC, Sekonic, DRTC. Worse, you can further manipulate the results based on how a test is conducted and what you want the results to be. We have companies fabricating their own in-house methodologies on how to measure DR and using it in their advertising material.
Also, as a CMOS sensor we know exactly what the sensor is doing and what this FalconBrid is doing. ADC is done on sensor, and modern CMOS sensors distributes current over multiple ADCs and isn't an issue for large photosites. Interpolation is done off-sensor on the FalconBrid, hence for this camera's DR is also a function of the gamma curve that is being applied downstream from the sensor.
