4k Camera for green screen sub $5k
Ken1212
Looking for a camera from a major camera manufacturer with sold reviews to shoot green screen in 4k. Built in zoom works but can also consider cameras with EF mount. I do like the C100 II except it doesn't have 4k, and the C300 II is out of my range. I am interested in the sony Z150 and the Panasonic DVX200. Form factor, I would prefer a video camera rather than SLR/DSLR, but open to suggestions.
As a DVX200 owner, I can only recommend this camera since I find it amazing for the price.
I haven't shot green screen works with it yet, but I suppose that it would be excellent for this purpose if you couple it with an ext recorder. You'd gain 10bit 422 in 4k!
The Sony X70 is great for green screen, and the Z150 is similar (slightly newer version of the sensor with 120fps and three lens rings) so I have to believe it's great as well.
"Shoot green screen" can mean a lot of stuff...
If you're talking about video podcasting, or a similar setup with a presenter or two, and you want background removal to add logos, sets and such… then I'd consider the Canon XC10 at least once.
I imagine a smaller sensor can do great for that kind of work and you get Canon Log, 4k with a good intra frame 305Mbps 422 codec.
For most people it's not an A-cam, but apart from the above situation it's great on a gimbal like the Ronin-M and it has very convenient time-lapse functionality. You can probably pick it up for $1600.
I am reading that the DVX-200 crops in 4k mode to 1" sensor is this correct? In this case what is the advantage of the DVX-200 over the Z150 or the X70 in 4k? The XC10 seems to be an interesting camera specially with it's 4:2:2 4k, my initial problems with it is no xlr audio, the extreme iris drop from 2.8 to 5.6 with a fixed lens. It's priced at $2k though. To narrow my options I need to understand which of those cameras will perform best in 4k with green screen, will the 4:2:2 in the XC10 out perform the other two?
No. It severely crops the sensor only in 4k 60p mode.
Take a look at some specs (from B&H):
Focal length: 12.8 to 167mm
35mm Equivalent
DCI 4K: 29.5 to 384.9mm
UHD 4K/30: 30.6 to 397.8mm
UHD 4K/60: 37.2 to 483.6
FHD: 28 to 364mm
I would just add that the main thing you really need is at a minimum 4:2:2 and 10 bit for clean green screen, and the DVX200 and z150 cameras are only 4:2:0 8 bit in 4K. You'd need an external recorder to get 422 10 bit out of either camera in 4K. But the z150 has built in 422 10 bit in HD.
I would just add that the main thing you really need is at a minimum 4:2:2 and 10 bit for clean green screen.
At one point I would have agreed with you. But to be honest I haven't had issues pulling a key in years using less than your quoted specs.
I agree with David. The keying software (check out the Hawaiki Keyer for FCPX, Premier and AE) is so good for so little money that you generally don't need 4:2:2 10 bit anymore to pull great keys. I normally am shooting 4:2:2 10 bit but my hard drive recorder broke down during a green screen shoot so I had to use my C100's internal AVCHD recording, which is a mere 24Mbps, 8 bit , 4:2:0 and and it keyed great. It's more about the lighting and how good you are with the keyer/edge cleanup/spill these days. If you have a choice, of course, always go for the best you can afford but if you can't afford 10 bit 4:2:2, you can still do some pretty nice keys.
Concerning color sampling I plan to shoot in 4k, now I have done basic green screen successfully with 8bit 4:2:0 in 1080p, with very clean results. By basic I mean talent standing or sitting and addressing camera without movement. Now I want to take my green screen work to the next level and start doing moving shots with motion and tracking work. I would assume introducing motion and and tracking would require a camera with better bit rate and color sampling, correct me if I am wrong. Out of the cameras we discussed the canon XC10 is the only one which is capable of doing 4k in 4:2:2 internally at up to 305Mbps, it is 8 bit though.
If I may be so bold as to suggest... Stop Jonesing for a new camera and start working on your skill set. You don't need a new camera to learn the craft of filmmaking. You need to invest the time.
All the best!
Dave
