greeches Veteran Jun 6, 2007 #1 Its having trouble reading over 3GB of ram. Identical 1GB RAM modules in all 4 slots... anyone overcome this issue? Its a P5B (non deluxe)
greeches Veteran Jun 6, 2007 #2 FIgured it out. Memory Mapping setting in BIOS opens up access to all 4 DIMMS.
K Kholi Section Moderator Jun 6, 2007 #3 What OS are you on? If your'e in 32-bit then ya won't see all 4 anyway. Only in 64-bit OS'
K Kholi Section Moderator Jun 6, 2007 #5 How do you see ALL 4 gigs in windows XP? As far as I knew, the max you'd see was 3.5gb
greeches Veteran Jun 9, 2007 #6 The BIOS was only seeing 3GB. Once I made the memory map change 4096 showed up.
