I need to be able to export my timelines using the QT.Animation Codec, and a lot of my work has alpha channels that need to use the color setting: Millions+ (as opposed to just 'millions' which does not allow alpha channels).
But what I am noticing is that you get an Export Error if you try to encode out anything bigger than 4 GB, which for my HDV work is about 30+ seconds, WHICH IS RIDICULOUS! This only occurs if you use the QT.Animation codec and have colors set to Millions+.
Is anyone else running into this problem?
