4:3 and 480p in DVD Studio Pro
JCVR
Can I get my progressive video to play in a 4:3 aspect ratio in DVD Studio Pro? As it is right now, it's only giving me the option to go widescreen.
Thanks for the help.
-JCVR
What are you compressing with? (compressor, QuickTime?)
How are you importing into DVD studio?
24fps QT -> DVD studio will not run at 24fps.
Not sure why you're forced into widescreen. All settings have option for standard or widescreen.
I was bring the AVI with the pulldown into DVD studio and then transcoding it in there.
what exactly is compressor? just a 3rd party app designed for compressing files?
Scottdvx100 said:
Compressor is an application that comes with FCP. Several choices and settings for outputting MPEG-2 files for DVD use.
Yes, it also comes with DVD-SP. I have the boxed retail versions of each and can verify.
The only way to burn a native 24p DVD in DVD-SP is to use Compressor (or any external encoder). There is no way to burn a 24p DVD if you encode in FCP with Quicktime, or AVI export. DVD-SP will transcode it (rather sloppily, and with an incorrect pulldown) to 29.97 if you import a Quicktime or .AVI
As I say, the only way to make a 24p DVD in DVD-SP is to import a previously encoded .M2T file. It just can't be done with a QT or AVI.
You must have compressor (or another external third party app.) !
