3D object problem
hawks66
so ive got these 2 small PSD files. i want them to rotate around the Y axis. ive turned them into 3d layers, but when i slide them to the edges of the screen i see them turn slightly. its no doubt due to some camera setting, but i have no camera set up! how do i keep them squared up when moving them to the sides of the screen?
its likely just due to perspective changes on the 3d layer.. im not sure what your trying to do, but if you just want to move the layers around without a 3d perspective, you could probably do it without them being a 3d layer. just keyframing the positions of the layers.
what are you actually doing
well, I understand your problem, I had the same problem for 2 months ago. But now I have started learning Maya (a 3d software), because AE is only a "2.5d" program. You will have to do all these in a real 3d software, render all with alpha channel, and import then as a tga sequence or an avi video to AE.
