thefilmaddict
I heard that stopping down on the HVX200 lens side somehow degrades the image and it's better to add ND instead while shooting outside in bright light. I may be wrong. Perhaps someone that already owns a Brevis will explain.
siniarch said:if the projection on the GG is too bright then detail is loss. using the ND from the camera won't bring back that detail it will just darken the highlighted area on the image.
Barry_Green said:It is acting like a projection screen, but there's no sensor or projector in the way, so what would blow out? Nothing blows out. Screens don't "blow out", only a sensor can do that. The image hasn't been "captured" by anything yet, so no limits on brightness have been established.
And anyway, I just ran the test, and made the image 256 times brighter than it was, and every speck of detail is still captured just perfectly.
THANK YOU!!!! this is what ive been saying for a year. People keep insisting that you have to "properly expose the GG"..... its a linear light transmitter, it doesnt care how much light it gets.Barry_Green said:This makes no sense to me. A ground glass isn't a sensor, it doesn't clip highlights, it doesn't have latitude, it's just a sheet of ground glass. How could you "overexpose" a piece of ground glass?
I just tried this with my L35FE -- I lit up a picture with a soft fluorescent light, no ND filter, camera wide open. Then I brought in a 1K fresnel, spotted in tight, and put it about six inches away from the picture. I had to put in both ND filters and also stop the camera down to about F/4, so that means that I lit the picture up to be about 256 times brighter than it was before. But it looked the same -- no blown highlights, no ground-glass exposure-induced weirdness...
So I don't get where this idea is coming from.
thefilmaddict said:Will I get that ONCE YOU GET A 35MM ADAPTER, YOU'LL WISH YOU ALWAYS HAD ONE feeling?
Abaddon said:I'm confused as to whether or not I need to get lenses with iris control. I'd like to get Canon EOS lenses but everyone's saying I'd have to use ND filters since the lenses are wide open.
