(Note that you absorb so much light going in either direction that you lose nearly two stops with these gels.)
nope. 2 stops for a full ctb, 2/3 stop for full cto. so you lose less light if you want to convert daylight to tungsten, which is why you'll more often see gels in front of windows than in front of lights.
Lucas, all helpful info. There was a time not too long ago that there wasn't really a choice to use daylight or tungsten (3200 or 5500). It was always a battle to fight the sunlight entering the scene using tons of light fixtures and amps. Dichroic filters were expensive (to convert 3200 to 5000) when it came to outfitting each light. Today we have a lot of daylight choices from CFLs or tubes, LEDS, etc. I made a decision a while ago to only use daylight balanced lights and I haven't looked back. As long as you have white balance the camera doesn't care what you use. It does care when you try to mix them, but that's another issue. I can shoot indoors with a lot or little sunlight coming in or even outside using lights to help lighting. Oh by the way, the CFL's, Tubes or Leds use only a fraction of the power, so I can even use an inverter in my car for truly remote recordings.
Gary
Gary
Given the rather poor color response of most video cameras, I'd use light with as much "blue" in it as possible. I use 3200/3500 balance only when I absolutely, positively, cannot use anything else. 5500 is always preferable if you can get away with it.
