I've not found it yet.. so I thougt..I'll post it here.
To make live easier concerning sound postproduction, it's always good to place a 30 seconds counting down clock, with on the 2nd second a "bip" (don't know if you say that in english that way) sound of 1 frame.
In industry parlance that's called a "2 pop" because it occurs two seconds before the first frame of video or film.
What you are describing in whole is called a "countdown leader," "SMPTE leader," or "Academy leader" depending on the details of what else appears on it.
The example you offered is the "SMPTE Universal Leader" (http://en.wikipedia.org/wiki/Academy_leader) and was used back in film and analog TV days as an aid for cueing up playback or projection.
In the age of digital, it is rapidly falling out of use because it is easy to provide the "metadata" using internal file tags and to edit the file so that the program material starts exactly on the first frame of the video stream.
