26 Volt Batteries and LED Panels
Hey, quick question about batteries for LED lights. I've got a 200 Watt LED panel that requires 26 volts. I didn't buy the dual battery plate that takes two 14.4 volt batteries and outputs 26 volts, I instead got a single 26 volt battery. The battery is AB mount, but now I'm trying to figure out if I need a specific battery plate with a dtap that outputs 26 volts. Most gold mount plates are rated for 14.4 volts. This one says 11-17volts and up to 50 watts, https://www.bhphotovideo.com/c/product/1279521-REG/shape_abgl_gold_mount_lock_plate.html. So I'm trying to make sure that I won't burn through the plate if I run the light off a 26 volt battery with a dtap to 4 pin connector. The batteries themselves do not have dtap connectors. I only found that out after purchasing.
