24PA to DVD
smpproductions
So I'm editing some footage shot in 24pa, captured correctly and on a 23.98 timeline. Everything looks pretty good, my question is, once I am ready to send this project to DVD ( I have iDVD and DVDSP) How should I go about doing the export and everything to keep the 24pa look or can I just export to an mov or mpeg2 and add it to a DVD project and burn like I do with normal 60i stuff? Basically, is there a different way I need to handle burning 24pa to DVD.
Export to compressor high quality 60min. Import to DVDSP. It's 24p in your edit and DVDSP is smart enough to keep the fps correct (even if it's not easy checking it)
DVDSP doesn't handle imported raw 24fps QuickTime correctly. (according to their docs)
I was going to make a similar topic, but figured I may aswell post here:
I only have iDVD. Is it possible/how can I make a (preferably high quality) DVD with that using 24pA footage edited on FCP?
Hi, I'm new to this forum and am having the same problem (3 months now!)
I shot 24pa footage using the dvx-100a and captured the clips at 23.98 using FCP 4.5 hd. I edited the footage on a 23.98 sequence and have tried everything to add the pulldown to export my project. I've tried printing to tape, Nattress filters, and CinemaTools, but they all result in a strobbing effect because of the pulldown issue.
I'll give scottdvx100's advice a shot since I've already tried everything else...
