khmuse said:There are a number of things that can cause this to occur, including:
Material is not 24PA in nature.
Cadence detection has failed due to a break in the time code.
Time line is not correctly set to 23.976.
By the way, interlaced and "jittery motion" may not be describing the same thing. You can have perfectly handled 24p footage that will be very jittery based upon how it was shot. Too fast of camera moves will yield a stutter to the image which might be misinterpreted as an interlaced artifact.
Post a frame grab and it will be easy to identify if it is interlaced or poorly shot.
FilmMagic said:FatBird,
I've been in so many forums talking about this and what it appears like, is that Premiere 1.5 really doesn't do that great of a job in handling 24p. I had to stop using it because everything I tried turned out bad. I wish you luck and please let me know if there is success.
khmuse said:Based upon your comments, I am assuming that it is likely that time code breaks are the problem.
A number of questions come to mind.
1) Is this the first footage captured from this camera / NLE combination?
2) Do you prestripe your tapes?
3) Do you review footage while shooting?
4) Do you use scene detect when capturing?
It is my guess that not every take on the tape is interlaced. If this is the case, and more specifically if it is takes past a certain point on the tape that exhibit the problem, then this reinforces the assumption of time code breaks.
Post your replies to the above questions and I'll respond with more comments.
