24PA Offline RT
hanguolaohu
I've used media manager to recompress already captured 24PA dv footage into 23.98 offline RT, and I'm encountering framerate and aspect ratio problems. The 24PA footage that I recompressed to offline RT remains in pixel aspect "ntsc - ccir 601". Put a clip into a 23.98 "ntsc- ccir 601" sequence with no problems. Just each time I open a clip in the viewer I have to uncheck "show as sq. pixels" so it doesn't look so, well... square.
Now I've got 30 more hours to capture, and not wanting to have to capture in full rez then wait for conversion to recompress, as well as dealing with problems of delete, shuffle, delete, I decided to capture in offline RT on the fly. I made a custom capture preset using photo-jpeg compressor @ 29.97fps and which removes advanced pulldown. Aspect ratio is multimedia large (4:3).
So I capture, and noticed 2 strange things. Under the pixel aspect column these newly captured offline RT clips are "square". I control-click, change it to "ntsc- ccir 601". That was easy. Also the "vid rate" is 29.97 rather than 23.98 like my other clips. Place into a 23.98fps sequence, and wham! Red render bar. I make a new sequence with 29.97fps and "ntsc - ccir 60" pixel aspect ratio and there's no red render bar.
So my capture setting is making 29.97 clips and is doing something strange with the advanced pulldown frames. Usually, if I capture 24PA DV footage, the TC cycle of the clip will be 30fps, but it will skip 6 frames every increment of a second. These clips I just captured don't skip frames in the TC. I triple checked my setting to make it almost identical to the "DV NTSC 48 khz Advanced (2:3:3:2) pulldown setting" under "capture presets", so I'm not sure what is wrong. I'm wondering whether Apple put some advanced setting in that Advanced pulldown preset that I don't know about.
Please help!
Thanks,
Alexander
Have you considered adding more HD storage and keep things online so you don't have to go back and recapture again? 30 hours would be about 380GB. That would cost around $300 for one 400 GB Firewire drive and would save you well at least 30 hours or redigitizing not to mention a lot of potential trouble.
Noah
