Jordanfilm
Ok, I just shot a short in 24PA. My goal is to output to internet (.mov,.mpg,.mp4), DVD, Mini-DV and VHS.
I'm currently using FCP4.
If I use sequence preset DV NTSC 48khz 23.98
Capture w/ DV NTSC 48khz (2:3:3:2) Pulldown Removal
and DCP: FIREWIRE NTSC NDF (RIGHT?)...
Will I be able to burn a 23.98 DVD in DSP2? Or will I have to convert it back to 29.97 NTSC before I can burn? If so, how do I do this and what program(s) should I use?
Will I be able to PRINT TO TAPE back to Mini-DV (or will I need to add a pulldown first)?
Will I be able to Record to VHS right from the timeline (or will I need to add a pulldown first)?
If any of you DVX guru's and wizards have any suggestions and/or advice, I'd greatly appreciate it.
Thanks!
Thanks!
