salils
I have been having problems capturing 24p advanced footage in Final Cut Pro 5.1.2 on an ocasional tape for a while now. As usual I used the advanced pull-down removal pre-set that is included with FCP. After capturing, I found that for some reason Final Cut Pro was setting my field dominance to lower! Because my settings don't match my sequence, FCP is forcing me to render. I've tried switching the field dominance to "none" as it should be normally be, but this doesn't fix the problem. I also tried removing the advanced pull-down after capture, but I get this error message:
Is there anyway to fix this?! I am able to capture small portitions of the tape, but I can't capture the 2-3 minutes in 1 clip that I want.
:furious3: :furious3: :furious3: :furious3: :furious3: :furious3: :furious3: :furious3:
