24PA Audio Sync Tool
I have the original DVX100 and I have the Audio Sync tool but I forgot how to use it!
I have it set to offset 4 frames. Do I add the offset while the clip sits on the timeline or no?
Heres the thing, I was working on a project over the weekend, and the audio was slightly out of sync. I didn't let it bother me, however I continued editing and when I exported via DVD and watched the video on my DVD player everything was in sync.
Which brings me back to the original question: Is there something I need to do to put it in sync while editing just by selecting the Audio Sync Tool or do like I did and not worry about it and print a DVD?
Read this: http://www.adamwilt.com/24p/index.html#AVsync
The offset should be 2 frames.
Select the clips in the bin and apply the audio offset.
yes, your audio will be out of sync unless you correct it. 2 frames isn't a lot and you may not notice it for some dialog but if you use a clapper or have a specific hit that you step through it will be off 2 frames.
