dvmichelle
Hello all,
My footage is a Mix Bag of 24p and 6oi
After messing up capturing footage into my FCP Using 24p Advance pulldown
I want to ask a follow up questions:
a - the corect capture setting is
"DV NTSC" IS at 29.97 fps (or DV-NTSC) setting
1 - For 24p what setting is best 4 rendering
My sequence should be set at? 23.98 FPS??
My Pull Down 3:2 is the highest quality?
2 - EXporting 24p into DVDSTUDIO 4
What is the format I should use to export Footage to
DVDSTUDIO4?
Keystone article is very confusing --
It suggest that I use QUICKTIME Movie (with default setting)
and it sayas in the same article the DVDSTUDIO pro does not treat this
out put right?
Can you all please advise?
Thanking you al in advance
DVDSTUDIO4?
out put right?
