24p on 30p timeline
reem12
I've commited the cardinal sin, by accidently recordin on two a1s in 24f and only recording one with the 2:3:3:2 pull down and the other without.
I'm using final cut 6.0 and I no that it's possible to mix differnt framerates on the timeline, but when I make the 24f with the 2:3:3:2 pull down as my primary footage, the 24f recorded without it plays chopy, but when I do it the other way around the 24f with the pulldown on the 29.97 timeline seems to play smooth.
my question is when I render down to my final quick time for dvd will I run into issues, and if so what can I do to make this mistake work? thanks.
HEE!!
I hope it worked for you. Sometimes you can run into issues if it wasn't captured and or shot properly.
Is it all working good????
CaptM
