24p images not fluid on PP2.0
Ogrus
I recently dumped a project filmed 24P into pp2.0 (actually 25p - i use pal- i live in europe)
The images on the working screen were not fluid, they had a certain amount of "laginess" or "chopped movement" It only happens with images in 24P, no problem with other scene settings (have not used f6)
I cant real edit properly!
Has this happened to anyone?
Thanxs
Ogrus
General:
Editing Mode: Desktop
Timebase: 25,00 FPs
Video Settings
Frame size: 720h 576v (1.067)
Frame Rate: 25 fps
Pixel aspect ratio D1/DV pal (1.067)
Field: No fields, progressive scan
Capture Format: DV capture
Video Rendering
Maximum Bit Depth: Off
Preview File Format: Video for Windows
Compressor: Cinepac Codec by Radius
Color Depth: Millions of Colors
If you've got a PAL camera and you're shooting 25p PAL, those settings should be correct.
Just make sure you don't use a 24p preset, 24p is a totally different game. It has to be distributed across 60 fields in NTSC, which gets complicated. You're just shooting straight up full frames at your TV standard's normal frame rate, so it shouldn't be having any trouble.
Oh, another thing to try: switch your preview file format to Microsoft DV, and make sure your timeline is preview rendered before you judge motion quality.
I´ll be trying that right away and let all know if its ok
Thanks for the help
You all rule!
