Chris Klidonas
Sorry if this is in the wrong place, I was not sure where to ask it.
As for the 24P cameras I understand the slower rate matches the film rate and causes the blur that better emulates film cameras frame rate.
So here are the points I am still after months of reading not understanding.
Some cameras shoot 24 and capture 24 and you see and edit 24, but the tv can play 60i so where does that change occur? This is cameras like a canon XLH1
Other cameras shoot 24 but capture it in a 60i and you see 24 on a tv but in order to edit it you need to do a pull down to make it just 24 not in a 60i ?
Is that right? and if so what difference does that make in editing?
And if you capture the 24 without the pull down, and edit it and then render a 24 movie for dvd which sees it at 60i does it matter?
What do you see visibly different? what are the problems with not doing a pull down?
What happens if you shoot 60i instead of 24 then edit it and render a 24 video for dvd?
I will tell you my issues, I don't see the major differences, but then I am not the only final viewer so I want to do it right. I shoot with the XLH1 and an HV20 and HG10, I know the XLH1 is fine, the others need to have a pull down, I do not do that yet, but I edit and output to a 24 HD-mov, or HD-wmv, or SD-dvd. I am thinking of a possible upgrade to a flash camera, either the HF10 or the SR11, the SR11 seems to have every benefit but 24p mode, and the hf10 has 24 but needs a pulldown, which I still do not understand at all.
What difference will I really see between shooting 24 in a 60i and not doing a proper pulldown, and doing a proper pulldown, and a camera that does not need the pulldown as it shoots it as 24, and finally a camera that shoots 60i only and is rendered in the final edit as 24? And if it helps I am using Sony Vegas 8 to edit and gearshift to make sd proxies and edit.
One other thing, if shooting in 24p is it better to shoot in 1/24 or 1/48? it seems the smaller canons want to default to 1/24th when in Aperture priority mode.
I am really sorry, it just seems that every answer I read is above my ability to follow or does not give any reasons for why or what the real difference is only you need to do this because type answers. I am sure there are reasons, and I really want to understand it, I think I just need one slow easy to follow answer designed for dummies to help me get the initial concept.
I hope someone can help.
Chris Klidonas
Chris Klidonas
