P Ptpiz Active member Jun 5, 2004 #1 When you export 24p from final cut pro, what do you set the framerate to in the codec options? 23.98 or 24?
toddmcm Carbonite Member Jun 6, 2004 #2 Re: 24p export standard 24P.... seems most guys that shoot in that mode choose 29 I shoot in 24PA in which case everything is 23.98
P Ptpiz Active member Jun 6, 2004 #3 Re: 24p export I shoot in 24pa and now export everything as 23.98, it is always much better that way if you use FCP 4.5 HD!
