dillont
Howdy,
Guess I'll strike out on a question...
I've got extensive experience in 3D animation and special effects. I also have the software/skills to be able to match moving BG plates with 3D elements, and composite 3D into live footage (a la Jurrassic Park and MIB).
The question is - what to do with footage captured on the DVX100 (should it be captured 24p, or 24pA)?
Once captured, I will most likely want to have the raw 24fps format to insert into the 3D program for timing, and the same 24fps to do the composite work on.
So which is better? 24p? Or 24pA? I'll need to remove the 3:2 pulldown from the 29.97 footage so its a pure 24fps sequence right? Export to image sequence or AVI format?
I've got some experimenting I'd like to do with my friend
Dillon
Dillon
