D dlion Member Apr 8, 2004 #1 can you use 24p and regular 30 in the same project? i have dvx footage and non-dvx footage. that i need to capture and edit.
David Jimerson Administrator Staff member Apr 8, 2004 #2 Re: 24p and 30 in same project. Yes, if it's a 29.97 fps project.
skettalee Well-known member Apr 8, 2004 #3 Re: 24p and 30 in same project. hmmm, can you have it play back changing from different fps' though?
David Jimerson Administrator Staff member Apr 9, 2004 #5 Re: 24p and 30 in same project. I should clarify, though, that that's OK. You'll still have the filmic look of the 24p footage, even in a 29.97 fps timeline.
mvb DVXuser Sponsor Apr 9, 2004 #6 Re: 24p and 30 in same project. You can convert the 30i to 24P with DVFilm Maker It will convert just about anything except 30P to 24.
David Jimerson Administrator Staff member Apr 9, 2004 #7 Re: 24p and 30 in same project. [quote author=Marcus van Bavel link=board=Vegas;num=1081443482;start=0#5 date=04/08/04 at 23:26:40]You can convert the 30i to 24P with DVFilm Maker It will convert just about anything except 30P to 24. [/quote] You can do that from within Vegas, too.
filmelife Well-known member Apr 12, 2004 #8 Re: 24p and 30 in same project. vegas can do that, check out the 24p white paper on sony's website, there's a link at the beginning of this forum section it does warn about loss of resolution when converting 30i to 24p, but it does allow you to mix the 30i and 24p, and render out to 24____or vice versa
