24fps Playback... A Question...
Polanski
Hi, I'm planning to buy an EDIUS NX PCI Express, and as I read in the specifications, it can play out video at 1080/24p and 720/24p.
My biggest interest here is to monitor in a 1080p LCD while I'm editing.
But I have a problem: I've been a Premiere guy, and I think that I should use Edius for this to work. I was about to buy a BlackMagic Deck Link Studio, but it only supports 1080/24p, not 720/24p.
I really appreciate anyone here using EDIUS NX PCI Express to let me know if this really works OK with 1080/24p and 720/24p which is the configuration that I'll be using the most.
Thanks for you comments.
Go for HD STORM am premiere guy too with matrox but when i downloaded the trial version of this software only, i can't believe what am seen.Edius Rocks!!
The problem with HD-Spark is that it only outputs 1080/23.98p. It niether supports 1080 / 24p nor 720 / 24p.
EDIUS NX PCI Express:
Technical Specifications
Video Formats (Capture)
  • Canopus DV - 720x480/59.94i (NTSC), 720x576/50i (PAL)
  • YUY2 (Uncompressed) - 720x486/59.94i (NTSC), 720x576/50i (PAL)
  • Canopus Lossless - 720x486/59.94i (NTSC), 720x576/50i (PAL)
  • HDV/Canopus HQ - 1080/59.94i, 1080/50i, 1080/30p, 1080/25p, 1080/24p, 720/60p, 720/50p, 720/30p, 720/25p, 720/24p, 720x480/60p, 720x576/25p, 720x576/50p
Video Formats (Output)
  • DV/DVCAM - 720x480/59.94i (NTSC), 720x576/50i (PAL)
  • HDV - 1080/59.94i, 1080/50i, 1080/30p, 1080/25p, 1080/24p, 720/60p, 720/50p, 720/30p, 720/25p, 720/24p, 720x480/60p, 720x576/25p, 720x576/50p
  • S-Video, composite - 720x480/59.94i (NTSC), 720x576/50i (PAL)
  • BNC component - 1080/59.94i, 1080/50i, 720/30p, 720/25p, 720/24p over 30p, 720x480/59.94i (NTSC), 720x576/50i (PAL)
Digital Video Input/Output
  • 1 x 4-pin FireWire
  • 1 x 6-pin FireWire
Analog Video Input/Output
  • 1 x S-Video and composite combined (7-pin miniDIN) input
  • 1 x S-Video and composite combined (7-pin miniDIN) output
  • 1 x component (BNC Y, Pb, Pr) output
Analog Audio Input/Output
  • 1 x stereo (3.5mm, unbalanced) input
  • 1 x stereo (3.5mm, unbalanced) output
  • 1 x stereo (RCA, unbalanced) output
What I don't really know is if the output for 1080/24p and 720/24p
are real time outputs to monitors, since the card only shows S-video and
firewire. Even though the specifications points out a component BNC.
This is really confusing. I don't want to buy something that I have to return.
Thanks for you input.
