23,97 / 25 fps multiclip problem
Hi, forum.
We are shooting a multicamera setup talkshow, with 3cameras, Canon EOS 5D, 7D and 550D, with 25fps. The standard workflow is conforming the footage from h.264 to ProRes and making a multiclip.
Accidentally the 5D settings remained at 23.98fps.
In order to create a multiclip of the 3 clips, the frame rate has to be the same. But neither conforming everything to 25fps, 24fps or 23.98fps with Cinema Tools works, the faulty 5D footage is always out of sync.
The problem might lie in the Settings Setup, but playing around with them didn't show any results either.
How should I proceed?
Thanks in advance for any suggestion.
Did you try a standards conversion? I have had success using Nattress plugins, if i remember correctly, there was a "keep sync" type of function that helped when converting for multiclip.
Jason
