I'm shooting a video MOS using 2 cameras. This is my first shoot using 2 cameras. If the two cameras are white balanced together using the same white balance board, both use the same iris settings, same scene file (scene file 6 / 24p), and both use the same Netural Density filter settings will the footage be identicial?
One is a DVX100a and the other is a DVX100b.
If I didn't have a field monitor should I be worried the footage may come out differently?
If I had one field monitor available is there a way to connect both cameras to the same monitor and switch back and forth to check both channels?
Thanks guys!!!
Thanks guys!!!
