Patryk_Rebisz
Besides Guy Holt's transformer any other solutions that one can buy?
Yes, but that's set up to take two circuits. A light isn't.
Yes, US 220 volts is comprised of two legs of 110 volts but to accomplish what Patryck is asking using two legs of regular (edison) is not going to work. Here is why. The common plug in a home is 15 amps, 20 amps max. This is not going to be sufficient to light a 2.5K HMI. .
Light only care about applied voltage, not the phasing of the legs used to create the voltage.
I'm not worried about the phasing, just the channel. It's about running two circuits through one bulb.
I'm not an electrician, so there might be a way; it just doesn't occur to me how to do it. I don't think there are any adapters which allow two outlets to combine into one, which is what we're talking about here.
Don't think in terms of circuits as its not really relative. Applied voltage is all that really matters.
There are no pre made adapters for this type of thing as it is not legal to do![]()
Keep in mind none of this legal under the NEC and not safe.
If you wanted 40 amps at 120 volt you could parallel 2 outlets of the same phase but separate breakers.
For 20 amps at 240 volts use 2 outlets on opposite phase.
What's a simple circuit diagram for running two outlets through one bulb?
You can say circuits aren't relevant, but you have to run the power somehow.
There's a difference between legal and possible, and if it's possible, I'd just like to know how it's done. I certainly don't advise anyone to do it.
NEC is code to be applied under new construction.
Maybe just change that to the NFPA requirement on non-modified, NRTL listed devices. K?
As I posted earlier take find 2 "circuits" both on the same phase and connect them in parallel for 120v 30-40amp.
Trouble with this is you will not get a true parallel due to wire resistance differences and more current will flow on the path of least resistance.
