hi in vegas 6.0 there is a settings that lets you change fram rates .im shooting in 24p and what setting should i have it set in vegas so i can edit with no problems whats the differnce with 2.397 or 24.000 thanks
NTSC video runs at about 29.97fps (30 times 1000 / 1001). For "24p" video to be displayed on 29.97fps TV sets, you have to alter the speed to 23.976fps and add 3:2 pulldown.
With the DVX, the footage is scanned 23.976fps to begin with and then recorded to tape with pull-down.
I think actual film cameras record at true 24.000fps. There is something really complicated going on with timecode and audio which I won't get into (because I get confused by it). To put it simply, the subtle difference between 24.000fps and 23.976fps can cause problems if you're not careful.
What...Glen....You mean then we will have to actually R&D how our video willplay on what TV and then make a master edit ? Gosh how is that possible. Lets say ive shot on a 24fps mode using the DVX. Now i create a timeline in vegas with project settings at 720x576 (pal) at 24fps and import from the DVX onto this timeline. Now lets say i want to burn a dvd with good clarity that would play as compatibly as any hollywood movie dvd. What format do we render out to or via DVD arch. Thanks.
There's no reason for you to work in 24p. 25p is what your footage is, and what you want to work in in Vegas. Then, just use PAL settings. Export as 25p or PAL, not 24p.
There is no 25pA -- there are no pulldown schemes with 25p/PAL. There is only 25p.
Oh ok...But David wont there be an actual difference in the highly revered 24fps format or film look versus the 25p ? Or is it that they look the same ? If thats true then is pal a natural alternate to film effect and framerates ? Also being higher in resolution.
