I never subscribed to that mindset. Yeah, you're seeing less of the recorded image when you letterbox - so technically, you're seeing less pixels and in effect, it's "less resolution," but you aren't "lowering the resolution" of the image that you've already captured. With or without the letterbox, whatever is in the 16:9 area (or 1.85:1 or 2.35:1 or whatever) stays exactly the same. When people say that letterboxing "lowers the resolution of your image" it makes it sound like you're somehow degrading the image that you've already recorded, and that's obviously not true.avatuar said:Don't you lose resolution when you crop it like that?
Jubal28 said:We're cropping to it, just like we would with 16:9 or 1.85:1. You have to make your own preset for it, though.
If that's all it does (I've never used it), then why not shoot in normal mode and have some room to crop in post? Both squeeze mode and letterbox mode seem utterly pointless to me if you aren't gaining any resolution from them. What would be absolutely fantastic is if they would offer a semi-transparent 16:9 overlay on the LCD to show you framing for that aspect ratio while you shoot, but not record it to tape. That way you have room to crop in post, but you can much better judge what you're framing for during production. Why no one has thought of this is beyond me.Jubal28 said:No. In squeeze mode, you're using the same number of pixels for the actual picture as you are in letterbox mode. What squeeze mode does is take the image between the black bars and stretch it into the full frame. It's the same resolution. (And it should be called "stretch mode," because that's what it does, but they call it "squeeze" mode, because that's what it looks like.)
Haakon said:If that's all it does (I've never used it), then why not shoot in normal mode and have some room to crop in post?
