indybones
Hi guys could do with a bit of help here please.
I'm creating some cinematic photographs and I'm wanting to specifically use a 2:35:1 aspect ratio (am I right in thinking this is the typical aspect ratio for cinema widescreen?)
I am having to stitch photographs together to produce a wide enough image, that ok, but I'm getting a bit confused with dimensions, cm's, mm's and ratios.
I have a train of thought here and it may be completely wrong, but if the ratio is 2:35:1 and I just continued to double that up ie
2:35:1
4:7:2
7:05:3
9:4:4
11:75:5
Will I eventually arrive at a number that can be used for a large enough photograph, what I mean is that if I were to use 2:35:1 in cm's then that would obviously be far to small but an 11:75:5 in cm's could almost be used.
Or have I just got this completely wrong?
Hope all that makes sense.
And thanks for your help.
Indy
2:35:1
4:7:2
7:05:3
9:4:4
11:75:5
Indy
