Not sure where to post this but I have a question regarding 16x9 SD footage and am interested in hearing other people's thoughts.
In the DV world, both 4x3 and 16x9 use the standard 720x480(486 for broadcast) frame size. For 4x3, the pixel aspect ratio is 0.9. For 16x9, the pixel aspect ratio is 1.2. When playing them back you are technically squeezing the video horiztonally to get your 4x3 image and stretching it horizontally to get your 16x9 image.
My question lies here.
Say you had an HD 1920x1080 source. You take that 1080 source, crop the sides off to get a 4x3 image and downconvert it to 720x480.
You take that same original 1080 source and downconvert it to an anamorphic 720x480.
Now both this 4x3 and 16x9 720x480 video have the exact same amount of pixels. However on playback, you squeeze the 4x3 image and stretch the 16x9.
Should the 16x9 image technically not be softer due to the stretching of the image? I thought thought not. I figured the 16x9 image should technically be just as sharp as the 4x3 counterpart since they have been using this method to create dvds for 15 or so odd years.
However in my tests this was not the case. When I downsampled the HD video and played back both the 4x3 and 16x9 SD video, the 4x3 image was actually slightly sharper.
Has anyone else done a test like this and come up with the same or different results? Am I just stating a well known fact here, or am I completely in the wrong here?
