15mm rods?
dbarak
Hi everyone,
I've been looking at various metal stock, stainless steel and aluminum, for 15mm rods, and everything I've seen is a fraction of a millimeter less than 15mm or a fraction over 15mm. Any suggestions about which way I should go, over or under?
Dave
15mm Rods
15mm Rods
Hi everyone,
Dave
I would definately go for the just less than 15mm. The Mattebox or 35 mm Adapter has provision to Tighten on a slightly less Diameter of 15mm.
Hi Syncman,
Your answer works for me! I figured the smaller size would be best, but I wanted to find out if anyone had dissenting opinions in favor of the larger.
Now the question is, are you using UK millimeters or US millimeters?
JUST KIDDING!!! Thanks! :beer:
If you go smaller, you can always put shims or tape on it to make it fit snugly. If it's too big....no dice. Get the smaller one.
