I just received a couple Cinevate Proteus baseplate systems with 15mm rods. The rods seem like they may be too thick, slightly beyond 15mm spec. I don't have a way of measuring accurately enough to tell.
I have a couple accessories for 15mm rods. One is a D|Focus follow focus and I was able to get it on the rods because it's a plastic clamp. The other is a Varizoom Riglits shock system and it's metal with a non-clamping side (just a 15mm hole) and a clamping side and I can't get it on at all.
I also have some IndiSystem rods from an IndiRailsPro system and those 15mm rods will not clamp tight in the 15mm clamp on the top of the Titan matte box I got from Cinevate.
The Varizoom Riglits piece slides onto the IndiSystem rods with no problem. So this leads me to believe that Cinevate's products are slightly beyond the normal 15mm spec.
Unfortunately that's all I have in 15mm gear, so I have nothing else to test with. Before I go to Cinevate with this, has anyone experienced this when trying to mix different manufacturers?
