AbracadabraFilms
I recently needed to do a series of run and gun indoor interviews that required a soft, even light source on the subject. There was neither the room nor the time for my Arri softbox so I tried out a 150 watt fluorescent medium based screw in bulb into a standard off the shelf clip on parabolic reflector. I clothes pinned a piece of diffuser material over the unit and used two of these set ups to light the subject. I was extremely pleased with the results. The lighting was soft (as expected from fluorescent) and easy to white balance to. I purchased the bulbs from Home Depot. They are $(8.99 each) made by Quick Start Technology for Home Depot. 150 watts of light ( no mention of lumens) puts out the heat of a 42 watt bulb and is warrantied for 7 years. They also work great inside a fabric Chinese lantern from Target . Makes a terrifc soft light source. They are not dimmable put compact enough to move easily. BTW, the diffuser material can be high heat bakery paper from the supermaket bakery isle. To protect the bulbs during transit, I use a cut off ribbed polycarbonate plastic 1 quart Gator Aid container. protects the fragile coil of the fluorescent lamp.
Best, Craig Hollenback
Abracadabra Productions
