I need to figure out what to do about powering a Carrion and mounting two V-Mount batteries that will give me at least 11hs...
I I guess I need two batteries, one dual charger and one dual v-mount rail mount.
I am trying to go as inexpensively as I can and do it right so I was looking at this package:
http://www.bhphotovideo.com/c/product/483420-REG/Varizoom_KN11S_KN_11S_Battery_and_Charger.html
or are those 3.3lbs each? if so then I will be set with two batteries and one plate, also only one charger should be enough
And then I couldmount one on the microPowerPod, but what I really want to do is mount two at the same time for weight balancing purposes.
Here is the microPowerPod... the V-mount is on the underside, but could I rig an other on the back off the wireless bracket?
http://shopping.netsuite.com/s.nl/c.472981/it.A/id.304/.f
