120v to 240v help
Andrew McCarrick
Carbonite Member
So I'm looking into getting a battery back-up unit to power some AC monitors on-set; which we'd charge each night. The only problem I'm coming across is I can't find a way to convert domestic based plugs (outlet I have to plug into), to a L6-20/30 (outlet of the battery back-up). I need the L6 outlets because the UPS systems with them have bigger batteries in them. I came up with a way to convert the 120v into 240v (via a transformer; http://www.voltageconverters.com/itemdesc.asp?ic=VC500W) but I can't seem to find a way to get the 240v output into a L6 outlet to plug the UPS unit into. Anybody know of anything to get from the consumer 220v outlet to a L6 outlet?
Changing plugs/sockets, or using adapters shouldn't be a problem.
If something is rated at at 20 amps, that means it is capable of supplying up to 20 amps to something else.
Amps are not "supplied", as such. They are "drawn" or "pulled".
Okay, thanks.... then that could be a problem right? Because I believe domestic outlets max out at 15Amps right? And the UPS system requires 20Amps. This all would be charged in a hotel room, so maybe they have 20Amp outlets?
Is the UPS 20amps on the AC side, or the load side? That's awful hefty for the AC side...
I it's the AC side, if the hotel has a circuit that can handle 2400 watts, you're golden. (Don't bother asking the desk about amps... maintenance might know, but "normal" folks will think in watts....like hair dryers and toasters and such.)
Can't tell. No mention of a fuse in the docs (the fuse rating would let the cat out of the bag).
The inverter/charger shouldn't draw that much. I've never seena rackmount anything that wouldn't run off "normal" household current.
But that doesn't mean this will. Sorry I can't help.
You could probably call APC and find out the specs, though.
