100B Settings for wedding
steveandbelinda
Does anyone have any specific setting on their camera that they use for weddings, that they would like to share? And does anyone use 24p or 24pA? If so, is there any differnce when it comes to editing? I use Vegas 6.0
I'm experimenting with the scene file settings menu, and not just sure what settings would be best for a wedding. Maybe if Barry could share his.
24P/PA is not the solution to every problem, and I don't think you should use it just because the camera can record it.
The couple probably wouldn't know film-like 24P from a hole in the ground and would prefer smooth-looking video of this special day, so unless you really know what you are doing, I would stay away from 24P/PA.
30p works well for weddings.
Better low light than 24p.
Not as stroby in medium pans as 24p.
You have extra frames with which to conform to 24p in editing for 80% speed slow-motion.
Not as video-like as 60i, not as film-like as 24p. I don't think wedding movies really work best at either end though. For event coverage that has to be dramatic and full of romance, 60i gives too much of a sense of immediacy and reality, whereas 24p distances the viewer from the material too much.
Shooting wedding dinner receptions, or church weddings can have dimly lit environments. Therefore shooting interlaced mode always produces a brighter image than progressive because in interlaced mode, the image (in fields) is captured twice as frequently compared to progressive.
Also, if you want to include some special effects like slow-motion or sped up video in post, then interlaced mode will produce smoother slow-motion effects.
I use 24p for all of my wedding shoots. If you know what you are doing and understand the limitations of 24p you're fine. It looks great and my clients love it. While 60i will get you "smoother" slow motion you can still get fabulous slow shots using the right software and experimenting with it beforehand. Always test your techniques BEFORE you are in an actual shoot or it will certainly come back to bite you. I'll check some of my scene files, see what I've been using as of late. Personally I like to shoot as flat as possible and then tweak things in post.
http://www.dvxuser.com/V6/showthread.php?t=100046&highlight=light+difficult+good
Bump up the master pedestal for those blasted reception shots. Wedding factories love to dim the lights for that "intimate" feeling, but it really does not bode well for the DVX user. As mentioned, file F3 is good for low light situations. And you can crank the gain, but it will make your image grainy.
As for your original query, I usually play it safe and shoot 60i. I may start to play around with 30p for single camera shoots. (Usually I'm shooting with non-DVX cameramen, and we want the footage to match.)
24p looks wonderful, especially for the ceremony, I just don't trust my skills with the camera to shoot a reception handheld in 24p. (Low light and strobing issues) If you can pull it off, more power to you!
