As my partner pointed out to me there is a problem with the math claimed by the press release...either the lumens-per-watt is incorrect or the number of amps the LED draws is incorrect. Both claims can't be correct. It can't be both because the numbers conflict with each other.
Not trying to be rude, but I don't see the problem with the math. 72 lumens per watt at 4 amps is about 3.6 volts - a pretty reasonable drive voltage for a single LED.
I have the cree upgrade for several of my Surefire tactical flashlights. They are a SIGNIFICANT upgrade in light output and quality.
