alexszo said:hi there
I just got a new jvc 101 and a had some problems with focusing. even though i adjusted the back focus, the lens seems to have problems -with low light and iris wide open- to keep the focus, when I zoom in and than back. the wide shots seems to be out of focus....
did anybody have similar experience?
it only happens with a open iris.
plus, the focus assist seems not to be always excately. the high-lightened lines, especially in a wide angel shot, indicate a bigger depth of field, that there really is. this syndrom happens again, especially with iris wide open.
so I ask again, if anybody made similar experiences?
Stevet said:You only need to setup backfocus under the follwing conditions:
1. New camera (You are now just mounting the lens)
2. You removed the lens
3. Someone dicked around with the knob that holds backfocus.
Use the chart I sent you and follow the setting backfocus instructions in the HD100
user manual.
No, once you set backfocus correctly, you are done. If it appears that backfocus is still out through the zoom range of the lens, I'm not sure what the issue is. Regardless, under this condition, I would bring it into a JVC service center to have them take a look.
PFP_VIDEO said:Micheal, I received my HD100 from B&H last Thursday, and it has the same problems as yours, at 0db also.
PappasArts said:Stevet
I bought some last night from an outfit in LA. 23 bucks and you get 3300mAh
http://www.calcellular.com/bn-v428u.html
