Finally! CCD specs and DSP released!
Jarred Land
President/Founder
Staff member
Courtesy of Panasonic USA
The AG-HVX200 continues to redefine high quality yet cost effective HD acquisition. From its inception, Panasonic intended to create a camera that could produce compelling content for the Independent Filmmaker and the News Stringer - as well as the wide variety of HD and SD professional applications in-between. While that seems like a tall order, we believed that it was possible because we had created such a camera in Standard Definition with our AG-DVX100 series. By analyzing its success, we worked to match its strengths with similar functionality in the HD Domain for the HVX200.
The Chip Set
All camera design begins with 3 elements: the image capture section, the signal processing section, and the compression storage section, and the most important of these is the Imager set. Knowing that the camera needed to do SD and HD, Panasonic surveyed the technologies and their respective “trade-offs”. If we used a 1/3" native resolution 1920 x1080 CCD, it wouldn’t have enough sensitivity to be practical in low light because the pixels would be too small to collect sufficient light. Likewise, a 1/3" 1280 x 720 native resolution CCD would require such a radical architectural change to achieve reasonable sensitivity and dynamic range that it would create image artifacts. These artifacts render the CCD questionable for many applications. Interlace image capture provides a gain in initial sensitivity that may permit smaller pixels but then the inherent image quality and flexibility of a true progressive imager is lost. With those options and limitations well defined, it seemed that none of these technologies answered the needs that we heard coming from customers. Customers wanted a camera that would perform in Low Light, have good Dynamic Range and still have the resolution to work in the HD domain.
Clearly the challenge in creating the best image was to find the optimal pixel density and size to balance sensitivity and dynamic range with resolution in a true progressive imager. The result? The HVX200 uses a technology that we have named Advanced Progressive Technology or A.P.T. This solution cleverly employs a spatial offset (a well known resolution enhancing technique) in 2 planes (biaxially) simultaneously to allow the use of larger pixels than one would have thought possible.
Take another look at the three technologies discussed above and contrast them with the Spatial Offset strategy. The chart directly below shows the native resolution of the Panasonic HD chip array along with others currently on the market. One can see only Panasonic utilizes biaxial spatial offset, that is both a horizontal and a vertical shift.
While pixel count is one of the many important factors that determine picture quality, it is not the only one that should be considered. Using a progressive type chip along with a precise implementation of Spatial Offset can optimize the resolution that is possible.
In general, two important concepts need to be considered:
(a) Spatial Offset technology will improve the resolution by a factor of 1.5 provided the gain in resolution is not offset by the quality of the lens.
(b) Interlace CCD resolution is equivalent to 70% of the vertical pixel count of the progressive CCD.
So, if one were to apply the Spatial Offset formula (for each manufacturer that has it) to their chip set and reflect the impact of being interlace (for those that are) the table above would be changed to the following:
Certainly this is a theoretical “best case scenario” and other factors must be taken into consideration when designing a camera such as the HVX200. For a 1/3” imager, increasing pixel density beyond an optimum level will decrease the Modulation Transfer Function, even though lines of resolution might increase. Modulation Transfer Function (MTF) is a quantitative measure of imager quality to describe the ability of the lens to transfer object contrast. Creating a good-looking and reasonably sensitive Standard Definition Imager in the 1/3” format is very difficult; creating a 1/3” HD imager with a usable sensitivity is even more difficult. Sensitivity and dynamic range are determined by the capacity of the charge well that defines a pixel, and this is determined by the size of that pixel. The grain structure of film must contend with the same rules. Big pixels or film grains are more sensitive than small ones, and smaller imagers require smaller pixels to achieve a similar resolution. For a camera to work in news applications, or any “run and gun” operation, a minimum sensitivity and dynamic range must be delivered.
Panasonic moved ahead with the decision to use a 960 X 540 progressive imager in conjunction with the Horizontal and Vertical Spatial Offset strategy. This strategy provides the HVX200 with the low light performance and the dynamic range that we’ve heard from customers was critical in their applications.
The diagram below illustrates how additional resolution can be gained by Pixel Shift or Spatial Offset of the red and blue elements with respect to green.
The optical block for this professional DVCPRO HD camcorder is assembled using highly accurate, patented technology to precisely set the Horizontal and Vertical pixel shift to ½ pixel. This gives the advantage of better dynamic range and sensitivity with minimal compromise in resolution.
Digital Signal Processing
The Optical CCD Assembly output (from the R, B and G image sensors) is then converted into a digital electronic signal. At this point the signal processing circuit becomes the next most important element in determining the camera’s performance. For the AG-HVX200, Panasonic designed a new Digital Signal Processing (DSP) chain using 14 Bit A/D conversion with a 19 Bit DSP system. This allows for extreme control over the images. Strategically this DSP is always working in the 1080 progressive mode (at either the 60 or 50 frame rate, depending upon the geographically defined model). This means the optical image is converted to a 1080 progressive picture (1920 x 1080 pixel count) inside of the DSP. From there all image processing will be performed in the 1920 x 1080 domain, and it is only after this stage that format conversion takes place. For example, if a 720P/24PN signal is desired, this conversion happens following the DSP image manipulation in order to produce the maximum image quality
Intra Frame DVCPRO HD Compression
The AG-HVX200 capitalizes on the well-founded and well-accepted extensible DVCPRO algorithm, an intra frame compression scheme that lends itself to post-production manipulation. Each frame stands on its own - data is produced and compressed independently for each frame, even in the case of High Definition. This maintains superior pictures and ultimate flexibility. This is especially true when shooting high speed moving objects, panning the camera, or employing the over-crank and under-crank capabilities of the camera. The beauty of the camera is that it can even act as its own frame rate converter so that special effects can be reviewed immediately.
Although AG-HVX200 is optimized for DVCPRO HD recording in either 1080 or in 720, it also works very well in the DVCPRO50, DVCPRO25 and DV domains. Having this flexibility makes it the GO-ANYWHERE, RECORD-ANYTHING camera.
All but the 25Mb formats sample color at 4:2:2, this means the luminance signal (Y) and the chroma signal (Pb/Pr) have a high quality color ratio. Because 4:2:2 sampling offers higher color resolution, it minimizes “jaggies” at chroma edges - and thus is suitable for image compositing (Top Illustration, below). DVCPRO, DV (NTSC), and DVCAM (NTSC) use a 4:1:1 sampling rate. DVCAM (PAL) and DV (PAL) use a 4:2:0 sampling rate (Second Illustration, below). Although these are formats where the color signal resolution is half of what one gets in 4:2:2 sampling, the degradation of the video quality during post-production is less than that from a structure like that of HDV, which uses a different version of 4:2:0 sampling wherein the luminance line does not correspond to the color difference line.
Ultimately all of the decisions that were made in the design, planning and development stages of the AG-HVX200 camcorder were to allow the capture of great images. If the camera as a tool stands in the way of creativity, Panasonic did not succeed in their objectives. The success or failure of those early decisions can best be judged by the resulting images. So far, the results have been resoundingly positive.
Yes, despite the pixel-count wars, I don't think too many people would be happy with how dark a high pixel-count imager would be.
Working as much as I have with digital still cameras the "bigger pixels beats more, smaller pixels" reasoning makes sense to me. Plenty of pro and consumer digicams with less pixels in the relatively same size sensor as a higher pixel model produce less noisey images, espeically in low light.
wow, this statement sounds like panasonic is defending itself. a brave decision to release pixelcount, which is below anamorphical pal resolution. the soft looking image of the hvx makes sense now. after reading this, my hopes of a higher res pal model have vanished and with sony`s new 200 frames slow mo hidef cam right around the corner, my decision becomes even harder now.
anyway, thx jarred for the info.
steindj said:
Oh boy. The pissers will be all over this. CRINGE. Oh well.
ha ha ha.
I think we all were expecting the numbers to be around here though.. and I think we all have gotten past the raw pixel count in determining if the camera is capable.
We have all seen some incredible footage from the camera already and thats pretty much all that counts.
Sure some people will moan and groan but those are the kinda guys that spend all day looking at pixels under microscopes rather then going out and shooting.
No more mysteries. The HDV's guru -- Steve Mullen was right, isn't it? And if now we know more it's because people like him or our Professor Bob Diaz in forums like dvxuser.com they could say what they have been saying. Kudos to the web democracy in order to one true info society and to the freedom of speech!
Woohoo, I get to post my message again!
Anyway, I was just saying that I guess my 1024x768 CCD prediction was wrong... Steve Mullen nailed it with his predictions/calculations. Anyway, I'm still very impressed with the level of imagery that Panasonic was able to pull from a 540 line CCD.
I dont know why i keep hearing this.. its very odd to me. The HVX compares to all other HD footage in this class, about middle of the road. Ive never felt the HVX footage to be soft, But i know it LOOKS soft on the low pixel flipout LCD... are you sure thats not what your comparing it too?
Oh I've always been with you and Barry on that, Jarred. But I can just imagine the postings that will be put on this thread tomorrow and other forums that will go yet unnamed. C-R-I-N-G-E.:rolleyes: :rolleyes: :rolleyes:
steindj said:
Oh I've always been with you and Barry on that, Jarred. But I can just imagine the postings that will be put on this thread tomorrow and other forums that will go unnamed. C-R-I-N-G-E.:rolleyes: :rolleyes: :rolleyes:
dont worry John will take care of those guys :)
I applaud Panasonic for the disclosure. It confirms what most everyone with the technical interest has surmised. It might be somewhat sobering, but come on, it's a good camera and it's time to move on and enjoy the creative output that will be flowing from the early adopters.
Now it's Canon's turn to come clean. 24F is very nice, but let's call it what it likely is: a very good real-time 48i deinterlace, or something akin to 24PsF, but my money's on the former. It's a virtual 24p that works too, so onward and upward, I say.
Lots of great options in this category and it can only get better from here on out.
Thanks for posting, Jarred.
Thanks for the update Jarred. I love what the HVX is producing.....
Honestly anyone spending time attacking panasonic on pixel count probably should put there energy into a project and get some work done.
Im still to this day so very impressed with Panasonic and what they have done in terms of 24fps. I could care less about how far they push the pixels- I just want the look of the DVX to evolve, which I feel it has in the HVX.
