Filmjunkie677 said:15 hours??
Posted at 7am, its now 4pm
Eastern time.... More like 8 hours.
Nice try anyway, Mikko. Time to brush up on your math skills or your timezone skills.
As an aerospace engineer for a living I may be a little more critical than the average joe but I am dissapointed in the construction. I currently have a Sony HC1. These weigh 1.5 lbs. After studing the construction I would be scared to put my 5+ pound HVX on it when it gets here. The gimbal is a tiny piece of plastic and will definately break eventually. The bearings are pins riding in the plastic which I bet will get sloppy over time.
A couple other gripes are: The Merlin comes with a beautiful case. The problem is if you configure the Merlin with the weights it does not fit in the case (very stupid). So to transport it you need to disassemble the Merlin. The case is big enough but the foam cutout in it is too small. Time to get out the razor knife I guess.
Another gripe is the large plate you attach to the underside of your camera. This plate is what you use to connect your camera to the Merlin. It slides on and there are some marks to help you get is located. The problem is the plate never goes on the exact same spot twice. So you have to spend a few minutes rebalancing the rig.
One last comment is the fold up feature. The ability to use it shouder mounted is a joke. If you put it on you shoulder the viewfinder is behind your ear and the flip out lcd is in against your nose. I guess if you dont want to see the image you are recording you could use it this way. Even with that issue I do like the fact it folds up. Makes it very compact for storage and you can rest it on your shoulder to rest.
My final rating would be a 7 out of 10. Functional but slightly off the mark. Not really worth $800, more like $500. I bet we will soon see some competition to fill in some of the shortcomings of the Merlin.
