thisiswells said:HD-DVD and Blu-Ray will also hold data-only.
Blu-ray.org said:1.5 How much data can you fit on a Blu-ray Disc?
A single-layer disc can fit 23.3GB, 25GB or 27GB.
A dual-layer disc can fit 46.6GB, 50GB or 54GB.
To ensure that the Blu-ray Disc format is easily extendable (future-proof) it also includes support for multi-layer discs, which should allow the storage capacity to be increased to 100GB-200GB (25GB per layer) in the future simply by adding more layers to the discs.
Philipp said:OK, I put it this way: I occasionally film events, footage for artprojects and mostly footage for advertising. within the last years I have been collecting many maaaany DV tapes I still want to use the footage from. If it was DVCPRO HD 1080 I reccon it might be several TB.
Still I don't think I spent more than 500,- Euros on DV tapes until today. I can label them. I can send them to collegues who want to use my footage, I can even just wach them on any cam.
Get my point? Ither you compress it or you store it on big HDDs or - and that's perhaps the option - you use a good streamer to archieve your footage in data.
xander76 said:Probably the best choice... will be normal data backup tapes. They can hold up to 400 GB or so... They are also fairly cheap
thisiswells said:Do a google search for "400GB tape backup"
The most affordable drive appears to be made by IBM and sells for around $3,100.00.
The data transfer rate is 35mbps. Still pretty cheap for the tapes, though.
xander76 said:Yeah, but 200GB tape drives are in the $1300 range IIRC.
