ahalpert
Major Contributor
You can always dim a light down or scrim it or diffuse it if it has "too much" power, but you can't add more power to a light that is underpowered to begin with.
Yeah I'm starting to conclude that I should suck it up and deal with a heavier set-up. The battery plate I have clamps to stand in a nice and compact fashion. The aputure battery bay looks more unwieldy. It'd be nice if someone said "of course you can use the same 2-battery bay across multiple lights as long as they have the same... (voltage/amperage/connector)" but I think I will bite the bullet and give the 200x a shot. It's still not a lot of output. The 60x probably a pipe dream. It's a bit seductive because of a similar output spec -- just with a 14-degree reflector which is on par with horizontal FOV of a FF 150mm...pretty tight...
