The thing is, a lot of the decisions being made aren't based off of what is possible today, but what was a decade or so ago when "posts" workflow was established. And a lot of these shows, the post team is set in their ways and those cats call the shots and run the show. It's based on what makes their lives easier. Side note: it's always irritated me how the people that sit in the climate controlled building in their comfy chairs with the luxury of getting an extra few moments to think about and check things, get to make all the decisions about how stuff is done in the field, regardless of how much harder it makes things, that are often in uncontrolled(less controlled) environments/situations.
The thing is, a lot of the decisions being made aren't based off of what is possible today, but what was a decade or so ago when "posts" workflow was established. And a lot of these shows, the post team is set in their ways and those cats call the shots and run the show. It's based on what makes their lives easier. .
There is also a vogue for shooting what is IMO 'too dark' Suprised by Oxford which I worked on seemed to be crawling around in the shade too much for my taste. Im not sure we ever got to properly enjoy the beauty of the starlet!
https://filmfreeway.com/SurprisedbyOxford
On a related note, I think it is too bad Sony never released a full-featured RAW recorder to compete with those from Atomos and Convergent. I own ad R7 and and an R5, but they aren't the same thing. It seems odd they'd build many cameras with RAW output -- but not give customers a Sony-built solution to record it.
Probably because that would put them in hot water with RED. They seem to have worked it out, because Venice 2 now does internal raw, or actually X-OCN.
Not many remember that Sony have two raw flavors. Sony RAW, which is a 16 bit linear 3:1 that was on cameras like the F55, and then when they got sued by RED for that, counter sued and then settled and now they have X-OCN which is allegedly 16 bit and maybe wavelet and maybe even basically is recode (by the data rate it matches) with a Sony header.
Buried in this you get a reference to F55 RAW vs X-OCN. No one shot the original Sony RAW format...the files were huge for when they introduced it.
https://pro.sony/s3/cms-static-conte...7495144176.pdf
External recorders suck. Anything more than 12 bit log, be it raw or not is great. large movies with have the budget for hard drives and the workflow. A lot of TV shows don't because they shoot more many more mins of screen time per day and many more cameras and speed is a factor because raw often is slower to transcode and you're shooting in Atlanta but post is in la so transcodes have to go though the internet so really good 12 bit log like prores 444 is plenty good enough.
As far as I understand, the RED patents only affect internal RAW, so there is a different reason Sony hasn't built one.
The R7 isn't part of the camera, it's an "external" recorder no?
ISo the basic atribute of raw is moot (not needed) in log capture.
With either raw or log you can get at the full range of the sensor.
Internal Log was objectively better.
If you have not read it, this test of the FX6 (and A7SII) of Log Vs ProRes Raw was interesting - Sony FX6 Lab Test – External ProRes RAW vs Internal XAVC-Intra | CineD
