G
Guest
Guest
But every stills camera has a base iso of around 100 for stills and a LOG base iso of 800 for video. And gets more DR from the raw stills. No?
No? i don’t know.
i haven’t done a lot of testing with raw stills. From what i recall about the 1DC, the highlights and shadows shifted when switching from C-log to Standard or Neutral picture style. So, the highlights were better in C-log, but the shadows weaker, and the overall equivalent Dr ended up being closer than i would have liked. but the noise to highlight difference was only about a stop push. so, i’m assuming that with the 1DC they gave it an under exposure and pushed it up for c-log. I remember that because it was annoying switching from video to stills and then needing to change my exposure by a stop to avoid a bad exposure.
but you are talking about a 3 to 4 stop push. i just can’t see that going unnoticed.
if you look at DXO mark dynamic range for the A7s3, the DR score around iso 800 is a bit closer to 13stops than the Canon R5, which again is almost identical to the CineD DR ratings for these two cameras.
But i never tested raw stills for DR at iso50 or iso100 before.
it should be simple to test for, because 14.6 vs 12+ is a big difference, and one won’t need a Xyla chart to be able to tell which has more DR.
