Mitch Gross
I met up with gaffer John Roche today to test out the new Nanlite Projection Attachment for Bowens Mount with 19-degree lens (that's literally the full name, code PJ-BM for short). This is basically a Source Four Leko barrel and lens that's designed to mount onto the Nanlite Forza 300 & 500 via Bowens Mount. Not all Bowens Mount accessories fit all Bowens Mount fixtures due to internal clearance issues, for instance this device does not fit on Aputure lights. I wanted to see if it played well with the Orion 300 FS.
They worked great together. With the included 19-degree lens (they also offer a 36 you can swap in) at 10' distance the output was a full three stops brighter than the bare COB alone. It was about 285fc bare COB v 2,500fc with projector. That's getting into JoLeko territory, and we're talking about a combo that's fully color tunable and under $2700 combined.
The Nanlite projector isn't perfect, and if you're shooting tabletop or in a small set where precision is more important than firepower than the Prolycht projection lens kit is the more elegant solution on a number of measures. Precision adjustment, rotating barrel, even brightness and focus across the field, smaller/lighter/cheaper, rotating thread focus adjustment instead of shoving the lens in & out, better tilt control, sharp as a tack with no color fringing, and so on. But if you want sheer power to pump into a bounce, beam into a CLRS board or push through a window like a sunbeam then the Orion/Nanlite combo is a great combination.
I work for Prolycht not Nanlite and don't get anything from their sales, but it's a great solution with the Orion 300 FS.
