Hi all,
most reviews I see are about how lightweight, compact or easy to setup they are. While easy setup is nice, the other criteria aren't very important for me.
What are the best gimbals in 2021 (they don't have to be new) for these criteria.
Criteria
Load capacity around 3kg (or more of course)
Best stabilization, also stabilization that eliminates micro vibrations/jitters.
Has the option to Pan/Tilt/Roll fast. Like whip pan fast. If not possible tell me which are the fastest ones.
Nice to have
Separate controller, to control from a distance. (Smartphone is ok, controller is cooler)
Setup movement pattern (all axis) that you can trigger.
Battery or it has separate batteries, or you can charge it while using, or the internal battery lasts really long
360° Roll
Easy setup (I read for instance a Letus Helix Jr. is more tricky to setup (micro jitters))
Not important
Lightweight
Compactness
Budget around 500 (of course lower is better)
Thanks!
Criteria
Nice to have
360° Roll
Not important
Lightweight
Compactness
Thanks!
