Hi all,
I was in the process of specing out my new PC build for HD editing - I was just about to push "buy" on an i7 setup, when I came across some comments on other sites that even with this high-powered rig, I would have problems with Real-Time preview in Vegas - specifically at transitions (which is exactly the place where you want a rock-solid preview!)
Is anyone sucessfully using Vegas Pro8, Vasst Gearshift, and AVCHD footage? That seems to me like the perfect solution (in theory). I have the demo of Vegas Pro8 (full version is on order), and downloaded the demo of Gearshift. Admitedly my machine is no powerhouse (P4 630HT @ 3.0G, 1.5GB RAM), but my first test on a 6-minute AVCHD clip (1080i60) got to "10% done", and then just hung Vegas (although the time-to-completion counter kept on counting).
I am playing around with the settings, but I just wanted to hear if anyone else has this working, to see if its worth persevering. If I can get it to work, I may be able to squeeze a little more life out of my current HW setup before upgrading...
Thanks,
Chris.
ps - I think the "perfect" solution would be to come up with an AVCSD format - drop the resolution by half in each direction, while keeping everything else the same. 75% less data should allow it to be previewed fine in most reasonable systems, and then you could just do a gear-shift-like replacement of the data before final render. The compression should be pretty quick - along the lines of DVDShrink
Thanks,
Chris.
