Sony EX3 vs Panasonic HPX500
Sorry Barry but I have yet to see an implementation of AVCHD that I call professional quality. Just like MPG2 suffers from certain compression artifacts more than DVCPRO HD, AVCHD just doesn't maintain the same quality as codecs like XDCAM EX even with the claimed approprate bit rates.
What circumstances have you seen AVCHD not match or exceed XDCAM-EX? As a recording format, not as a camera head, because obviously those are different...
If I want quality I can use 100Mbps MPG2 and get uncompressed 8bit quality and much easier post production workflows all to even cheaper CF cards.
Yes, but -- that's using a separate $5,000 product. How is that relevant? I mean, could an HPX300 or HPX170 user not use that exact same product and record 35mbps MPEG-2 to those same cheap CF cards? If you're going to bring an external recorder into the mix, that works both ways. I could just have easily said "if I want long recording times, I can use 35mbps or 25mbps MPG2 and get long recording times on cheaper CF cards."
But what do you mean by "much easier post production workflows"?
So I stand by my statement that SxS is lower cost per min due to the codec manufacturers are pairing too it.
If we're staying with the onboard recording codecs, then I say that in 720/24pN it's almost identical record time per minute, and if we're using AVC-I 720/24pN or 1080/24pN at 50mbps it's comparable record quality and almost identical record time per minute, and if you're using AVC-I 50 in any other mode it's reasonably comparable. The concept of 3x as much recording per gig doesn't apply, it's more like 1.3x as much recording per gig, which is reasonably comparable.
It's only when you want to compare AVC-I 100mbps against XDCAM-EX that the recording time per minute becomes significantly different, but *so does what you're recording* so how is that a direct comparison?
AVC-Intra is a bi**h to edit in post without conversion to some inter codec.
Says who? Have you ever tried it? AVC-Intra is effortless to edit in post as compared to long-GOP MPEG-2! AVC-Intra plays in realtime on my LAPTOP. EDIUS plays it in realtime with no GOP issues.
Now, AVC-HD is another matter, it's quite a bit slower than AVC-Intra. But AVC-Intra is no big deal, and that's on a 2.4GHz laptop. Use it on a quad-core or octo-core desktop and it screams.
I also find it incredibly hypocritical that Panasonic all along trash MPG2 being highly compressed LONG GOP codec of DVCPRO HD and now start trying to promote the use of AVCHD in their lower end Semi Pro gear to compete with HDV and XDCAM EX as it is even more compressed and also uses LONG GOP. You can't believe anything Panasonic say about codecs with such a clear history of twisting the truth to suite their marketing needs...
Trashing long-GOP and then embracing long-GOP does seem like quite a fine line to dance for them. Almost as hypocritical as Sony claiming that AVCHD is a "consumer" format, while pushing HDV as "professional". Doesn't that seem equally ridiculous? I can't help but laugh my guts out when Sony says that a V1U, V7U, Z1U, or S270 (have you seen the S270?) are "professional" products that use 25mbps of 1440x1080 HDV, but then they say that 24mbps of 1920x1080 AVCHD is "consumer". And, at the same time, SONY THEMSELVES say that 9mbps of AVCHD provides an equivalent picture quality to 25mbps of HDV. Yet 24mbps of AVCHD is "consumer" and 25mbps of HDV is "professional"? It's ridiculous in the extreme. Kind of like Sony saying that 4:2:0 is just as good as 4:2:2, and then coming out with their own version of 4:2:2. Or them saying that 25mbps is good enough, and then coming out with 35mbps and saying "that's good enough" and then coming out with 50mbps... If 35mbps is good enough, why go 50? And if 50mbps of MPEG-2 is good enough, why go with AVC? And they will, you just watch... and when they do, they will look profoundly hypocritical.
There's "marketing" going on, on both sides. Both sides have to sell what they've got on the shelf.
So is there any truth to be had anywhere? Long-GOP sucks, right? Yes, it does - when the bandwidth is too low. Long-GOP can be very helpful if there's enough bandwidth so that it doesn't screw you over. Using Long-GOP as a crutch to prop up your too-low-bandwidth video does indeed suck, and that defines HDV in a nutshell. Using Long-GOP to give you better video quality at adequate bandwidth is a perfectly valid technique, which is why I don't doubt that the 100mbps long-GOP of the XDR will look as good as the 160mbps I-frame version. I have tested the living **** out of HDV and can break it all day long, it is NOT good enough. I have tested AVCHD pretty well and cannot break the 24mbps version no matter what I try. I find it at least as robust as XDCAM-EX. At least. If you've seen otherwise, I'd love to know the circumstances.
The way I see it, Sony has historically come up with half-assed recording formats that they shove out the door, while Panasonic at least takes the extra effort to make their professional lineup be more professional. What do I mean by that? Look at DVCAM. Sony took the exact same DV format, sped up the tape 50%, and called it "DVCAM". Panasonic took the same DV format, put it on much more durable metal particle tape, widened the track pitch out further, and sped up the tape even faster. DVCPRO slew DVCAM, over 2/3 of broadcasters in the US replaced their BetaSP systems with DVCPRO, and Hitachi, Phillips, and Ikegami all licensed and manufactured DVCPRO gear; nobody licensed DVCAM.
For HD, Sony took the exact same DV tape and mechanisms that they already had, and used that as the basis to build their HD system. Didn't matter how much bandwidth you'd actually need for quality, they were restricted by what their hardware and tape could handle, so 25mbps was it. They called it "HDV" and shoved it out the door. And it sucked. Panasonic instead took their exact same DVCPRO-HD format from the VariCam and put it on P2 cards. We're talking about the exact same format that had already been certified for unlimited acquisition *and post* by Discovery HD. Same format.
For "enhanced HD" Sony took a blu-ray disc with a maximum write speed of 35mbps and juiced up their HDV format to match what the disc could handle. Again, the defining idea here wasn't to show off the ultimate in best formats, it was to hawk proprietary hardware and proprietary media, and the format was limited by what the media could do. So that's where XDCAM-HD came from. And for EX, they stuck with the exact same bandwidth restrictions for *no conceivable reason*. They claim the card is capable of 800mbps, yet they limited the recording to 35mbps of 4:2:0. Why? Who knows? Panasonic instead counters with 4:2:2 10-bit AVC-Intra, which is HDCAM-SR caliber recording.
So now Sony is introducing 50mbps of MPEG-2. Seriously? With a straight face? Sure, it has 4:2:2 now, finally. But come on... and yes, of course, it's disc-based and requires its own proprietary media and its own custom expensive deck. Whereas Panasonic will re-use the same P2 cards and could introduce a 200mbps "ultra-AVC-Intra" if they wanted to, not costing the user anything additional. Or, they could put AVC-HD on the cards if people want long record times. Doesn't matter. What matters is that the recording media and the flexibility stay the same, and the quality exceeds anything the other side produces.
So yes, they went long-GOP, but at least they chose the best codec they possibly could, AVC. Sony uses 1990-era MPEG-2, Panasonic uses 2006-era AVC. Same pattern holds: Sony half-asses it, Panasonic at least does what improvements can be done. If you're gonna go long-GOP, at least use the best technology available, right?
Its a catch 22 though, for the most part, those happy to pay the price for the P2 media arn't going to want a 1/3" camera, and those happy to work with 1/3" cameras arn't going to want to pay P2 prices.
So nobody bought HVX200s or HPX170s? 1/3" P2 is far and away the most successful, most widely installed base of P2 products. And NBC, CNBC, and Telemundo just bought loads of 1/3" P2 product, both the 170 and the 300.
If it had used SDHC instead, you'd have many many more users ready to just onboard (I'd be interested myself), even if it had both media slots and you used your prefered media for the job and what was required for the write speed.
Agreed 1,000% and I sure wish they'd do that. There's an SD slot *right there*, so why not let us have both and switch to whichever media we want depending on the job? That'd be fantastic.
Seems everyone is forgetting about the Firestores. They Bring the cost of recording down considerably especially the 250 gig for DVC pro HD.
Getting 4:2:2 at 720p looks pretty good.
Thanks for the video Zacuto!
FireStore doesn't do much of anything for either of these though. AVC-Intra and XDCAM-EX don't stream out the firewire port so you can't record those on a firestore at all. The only thing you can get out of an EX1 or EX3 is HDV, and the only codec you can stream out of the HPX300 is DVCPRO(including 50 & HD).
If you want 10-bit 4:2:2, you have to either record to the onboard AVC-Intra on the 300, or connect via HD-SDI to an SDI recorder like the P2 Portable. The Convergent XDR is 8-bit only.
Correct; it's pre-filtered (960x720 instead of 1280x720) and 8-bit. AVC-Intra is full-raster 1280x720 and 10-bit. But they're both 4:2:2.
HPX300 vs. EX3 Rolling shutter example
Several people have been asking me to post some examples between the Panasonic HPX300 and Sony EX3 rolling shutter. Check out this video and you decide: http://vimeo.com/3367266
Steve Weiss
Thanks for your reply Barry. Well put as usual.
It is obvious that Panasonic has to cater to their largest customers and I don't blame them, but I agree with the posts about recording options.
If they could put the SD card mechanism and give everybody a chance to use the camera wouldn't that be best?
It does look like a protection of the P2 media.
The SD card would most likely limited to 50Mbps which is fine. That would give the P2 memory a leg up.
But don't leave out compact flash cards as the Flash XDR can record decent bit rates on $80 32gig cards.
I have a camera to purchase and the EX-1 is ahead solely on recording length with the M&R SD card hack.
Just thought it was important to demostrate that Panasonic will miss out on my business because of the P2 format.
I already own Panny cameras, but can only afford one Flash XDR.
Converting XDCAM EX footage to high bit rate AVCHD introduced noticable degredation of image quality. There are no professional grade AVCHD cameras to shoot directly on.
Its relevant because it is a real usable option, and shortely it will bemore like $3.5K so comparing costs, now much is an EX1 with nanoFlash cost compared to HPX300 + NanoFlash + P2 media? Completely difference league in prices. Why would you go with a 1/3" camara when you can get higher quality out of a less expensive 1/2" solution?
Yes, of course, never said they couldn't (as long as they have the same HD-SDI out) but with the same or high quality can be had for much less cost with the EX series so why would you?
I have a close friend with a HPX3000 and he shoots in DVCPRO HD because the post production problems with AVCIntra are just too much for him to deal with. He has to work in uncompressed as his Dual Quad Core Xeon with Premiere + MAtrox AXIO gear just can't handle the codec.
Les be real, what % of users shooting at 720p?
DVCPRO HD is 100Mbps at 1080 and to get the quality out of Intra your going to shoot at 100Mbps otherwise you might as well shoot XDCAM EX or your left with a 1/3" camera comparable to the JVC 700
But everything everyone says about this camera is about how great it is too shoot at AVC-I at 100Mbps, so it is relevant.
See above for why I believe AVC-I is very processor intensive to decompress. By the way WHAT GOP ISSUES? I have NEVER had any GOP issues, 'GOP issues' are bulls... I have always edited LOGP GOP EXACTLY the same as DV. The fact it is LONG GOP has always been transparent to me.
Trashing long-GOP and then embracing long-GOP does seem like quite a fine line to dance for them. ...
The difference is that Panasonic will publically attack in both marketing print and in forums Sony's decisions and implementations (goodness know how much Jan trashed HDV & LONG GOP but you find me anywhere Bob Ott trashed DVCPRO HD), then a while later make those same choices. Sony on the other hand only market what they use, not trash talk the competition. It's no different to how AMD always trash Intel products but you never see any public trashing of AMD by Intel. Its a clear sign of a company fighting to play catch up and very poor form...
Rubbish, it does NOT suck, this is just what Panasonic have brainwashed people into thinking.
When the bandwith is too low ANY codec suffers. I never went HDV but for certain markets it is a perfectly acceptable compromise.
Panasonic still force you to use P2 rather than more reasonable media options. They are no angle and where they give in one hand they take on the other.
P2 is proprietary
and its own custom expensive deck./quote]
You seen the price of a P2 deck? Much more than the Sony U1 deck.
But they havn't, why is that? Its ok to hold back codec options for Pansonic but not for Sony then? They could both do a lot if they 'wanted too'
Ahh yes it does matter because they havn't done it.
the media isn't important, its the cost of the media. Flash is Flash, as long as it works.
AVDHD is a consumer format and I see compression artifacts all though it all the time, its a pain to work with and is a very poor codec for professional gear. It requires much higher powered encoders that are less mature and produce sub standard results, maybe in a few more generations this will improve but AVCHD is about as good now as HDV was when it was introduced.
Its relevant because it is a real usable option, and shortely it will be more like $3.5K so comparing costs, now much is an EX1 with nanoFlash cost compared to HPX300 + NanoFlash + P2 media? Completely difference league in prices.
I still think you're mixing metaphors and leaving parts out. HPX300 + nanoflash = about the same cost as EX3 + nanoflash. HPX300 + nanoflash+p2 = about the same cost as EX3 + nanoflash + SxS. They're the same cost. In fact, an HPX300 can be bought for less than an EX3. Ex1 is, of course, different but then again it's entirely a different type of camera.
Is this a serious question? EX1 vs. HPX300? You do realize one's a little handheld ergonomic disaster, and the other's a full-size interchangeable-lens ergonomic dream, right? There's a world of difference between them long before you even get to the chips.
I mean, if all you're talking about is eventual image quality regardless of what it takes to get there, then that would be the same type of argument that a Scarleteer would say, as in "why would anyone buy an F900R when they could have a Scarlet instead at less cost?" There are a million reasons why. If they don't apply to you, fine, but that doesn't mean they're not valid reasons.
Well, Premiere and Axio don't support AVC-Intra. It has nothing to do with a Dual Quad Core Xeon. If he ran EDIUS on that system he'd probably find he could get multiple streams of AVC-Intra running full-screen with no problems. You can't say that Intra is a pain to edit when the system you're using to compare it doesn't even have Intra support!
Well, let's see... there are two major networks in the USA that have converted entirely to P2, and one of them is entirely 720-based (Fox) and the other is 1080-based (NBC). Then there's the vast majority of P2 cameras being HPX170s and HVX200s, and I'd guess that probably 80% of those are being used in 720p mode. So my guess is probably half is being shot at 720p, overall.
Sweeping statements with little to back them up. AVC-Intra 50mbps is going to be at the bare minimum comparable to XDCAM-EX, and 1080 @ 24fps is going to take up 40 megabits per second, directly comparable to XDCAM-EX. Just because you can go to more, doesn't mean you *have* to.
I don't know what you've done or where you've been, but that's not the experience the rest of the world has been having. First of all, when I say GOP issues, I'm talking about what happens to the footage in-camera, not post issues. The biggest post issue with the GOP is when you go to conform the footage for output, that's when you get an exceptionally long render time that you never would have had with DV or any intraframe-based codec. To say there's "no issues" is way oversimplified; I mean, look at Discovery's requirements for editing and mastering: no form of GOP codec is acceptable for editing or mastering. Only intraframe is acceptable to them. There are reasons for that.
But that's not what I mean, I mean that when the codec is stressed beyond the capability of the long-GOP to overcome its bandwidth-limited issues, then very real and substantial degradation happens to the footage. It goes blocky. It loses color detail. It gets nasty. That happens because it's a long-GOP codec that's trying to use the GOP structure to overcome its bandwidth-limited structure. If they had enough bandwidth it wouldn't be a problem, but they don't, and so therefore it *is* a very real issue.
I don't know whether to laugh or cry at this statement. Have you ever *attended* a Sony presentation? They're the biggest pack of lying attacking liars I have ever seen. Let me give you a few examples:
1) at NAB 2007, they had a presentation with a P2 card on it and a big circle and a slash through it, proclaiming and even saying "P2 IS DEAD". Really? Seems like capturing 85% of Europe and 75% of America (so far) isn't exactly "dead", but that's one of many trash-talking scare tactics they tried to use.
2) at NAB 2007, their personnel were saying direct lies such as "you can't put a P2 card in your pocket; if you have any spare change in your pocket the coins will rub against the card and create static electricity that'll erase the card." A stupid lie and easily completely disproved; I put a P2 card in my pocket with about 100 coins in there and swished it around for a half an hour walking through the Las Vegas casino, then threw the card on the ground and rubbed it in the carpet to build up some static electricity, then put it in the camera and ... guess what ... it played just fine.
3) at NAB 2007 they were also saying that you can't get a P2 card near a CRT monitor because the "magnetic waves" will erase the card! How retarded. I took that same P2 card and rubbed it all over the front and back of the CRT-monitor slot machines, then played it, and guess what -- it played just fine. Another Sony lie easily disproved.
4) Sony went around our country, and around yours, with a presentation that was called something like Long-GOP vs. Intraframe: "The Facts" or whatever. And in that presentation they purported to show examples of multi-generation recompression comparing XDCAM footage against AVC-Intra footage, and showed how XDCAM footage held up more robustly in multiple generations as compared to AVC-Intra. THIS WAS A COMPLETE FABRICATION. A total lie. They never had AVC-Intra to begin with. What they did was, they went online and found some open-source AVC codec from some Belgian computer programmer, some guy who'd posted his free codec, and they used THAT as their basis of comparison. They told people it was AVC-Intra, but it wasn't at all. They showed photos, which were completely bogus. They showed this presentation publicly and they showed it to places like CNN, and they actively deceived people into thinking that what they were seeing was an actual codec comparison among competing products. But it wasn't, and in fact it was impossible for it to have been true, because AVC-Intra hadn't even been released yet! A pack of lies, attacking a format that is easily provable to be highly superior. I mean, while they were out there lying their asses off about AVC-Intra, the BBC was busy choosing it as the core standard for their Digital Media Initiative and Discovery was busy giving it their highest "Gold" rating. Where's XDCAM on that list?
5) Yet another Sony presentation went about comparing XDCAM to AVC-Intra, and they put in a slide saying "The EBU tests confirm what we're saying." This was a bold-faced lie, and the EBU called them on it, demanding that they immediately discontinue that presentation and send out a public apology and clarification to everyone. Sony was forced to admit that they lied about this.
Look, simple fact is Sony's desperate, they're shedding market share like nobody's business and they're trying anything and everything they can to scare customers. They have no honor and no integrity. They are far guiltier of the exact same things you're accusing Panasonic of.
Oh, here I agree with you. I just think you got the players backwards, is all. :thumbsup:
I like to consider myself "not" brainwashed. Long-GOP clearly DOES suck, depending on the bandwidth allocated to it. And it's easily demonstrated as to when the issues happen.
If you can allocate enough bandwidth, it stops being a liability and can start to become an asset. 100mbps of MPEG-2, long-GOP, should be perfectly fine and immune to GOP-based artifacting. 25mbps of MPEG-2 is way underpowered and very prone to that same artifacting.
Okay, fine, they "force" you to use P2. Rather than "forcing" you to use XDCAM, or XDCAM-HD, or XDCAM-422, all of which use the same basic type of optical disc but all of which are completely incompatible, and all of which are proprietary media. Or SxS, which is a proprietary media. Or any other proprietary media. Whatever. But at least recognize that P2 is unlike any other type of flash memory. P2 cards have their own microcomputers built in, they have their own firmware, their own processors, and their own RAID controllers. A P2 card is not a memory card like any other. Doesn't have to make a difference to you, if you don't want it to, but it's the reason they're so different.
I must ask what you're talking about here... because I do not have any idea. The Sony U1 deck is $3,000 at B&H. A Duel Adapter for P2 is $119. A PCI slot reader for P2 is $75.
Even if you went with the most expensive 5-slot P2 reader, the PCD35, that's $2,000, still way less expensive than the U1.
Why haven't they? Because when you're already offering HDCAM-SR caliber recording in 100mbps, what's the incentive to go to 200mbps or more? To what purpose? They *could*, yes, but why? Will it gain them one more customer? Probably not. They're already delivering HD-D5 quality recording at full raster, 10-bit, and intraframe -- how could they improve on it? What would more recording bandwidth get them?
Whereas with XDCAM-EX, they've already shown that there's definitely more that can be done; the PDW700 uses 50 megabits and gives you 4:2:2.
Point is, Panasonic's giving you their very highest quality codecs in a totally un-crippled form; DVCPRO-HD at full bandwidth, AVC-Intra at full bandwidth. And there's room to grow if they decided to. But Sony, instead, for no discernable reason, is sticking you with a 35mbps version when they already have 50mbps; they're sticking you with a 4:2:0 implementation when they already have 4:2:2, etc. In fact, the very same NanoFlash and XDR that you're singing the praises of, which has the ability to go to 100mbps 4:2:2 long-GOP and 160mbps 4:2:0 intraframe... that very same product uses the very same codec chip as the EX1 and EX3. So could Sony have put 100mbps 4:2:2 in the EX1 on SxS? Obviously. Why didn't they? That's a question you'll have to ask them. Panasonic *did* give us 100mbps 4:2:2, Sony didn't, and as near as I can tell there's no good explanation for it.
If this is your perspective, then there's no point in discussing it further. Suffice it to say that this is not the perspective of the networks and broadcastes who have overwhelmingly chosen that the media itself *is* important, having an indestructible fault-tolerant media is very important, and cost is not the overriding factor.
Have you ever held a P2 card? And an SxS card? Have you noticed the difference in ruggedness? Read the Sony EX1 owner's manual, it'll tell you that you shouldn't use your cell phone near SxS or it might screw up the recording! You think "the media isn't important?" If that's truly what you think, then okay for you, and P2 is most definitely not for you. But for the customers to whom these things *are* important, they seem to value things such as that rather highly.
AVCHD is a substantially better format than HDV. SONY THEMSELVES have said that 9mbps of AVCHD is visually equivalent to 25mbps of HDV. NINE megabits. Yet Sony themselves offer HDV as a "professional" format. So let me ask you: how can you say that 24 mbps of AVCHD is "consumer" and 25mbps of HDV is "professional", when Sony themselves say that 9mbps of AVCHD is equivalent to their "professional" format of HDV?
You say you see compression artifacts "all through it all the time". Have you ever used PH footage from an HMC150? I'd love to see some of those compression artifacts pointed out.
As for it being a pain to work with: guilty as charged. As for it being a "very poor codec for professional gear", nonsense -- at least in the context of HDV or XDCAM-EX. If 35mbps of MPEG-2 is appropriate for professional gear, then 24mbps of AVC is most definitely equally appropriate for professional gear. Look, if you're using bad software you can hardly blame the format for that; Premiere plus Axio is a DVCPRO-HD system, not an AVC-Intra or AVC-HD system. Have you tried playing back AVC-HD in Nero? Little consumer app Nero can play 1920x1080 footage at full-screen, full frame rate, on my laptop to an external monitor. Software will catch up with AVC-HD.
Yes it's early. Yes the software support is, as of today, immature and needs to get better, all that's true. But to imply that the XDCAM-EX or HDV codecs can do anything the AVC-HD PH-mode codec can't do... I reject that completely, absolutely, and without exception. That's just plain wrong.
Isn't it stupid to use P2 while you can incorporate a removable solidstate harddisk of say 250GB in the camera. If it is not stupid, than it all has to do with ripping you off or forcing you to buy the goldplated wonder memory so called P2.
Your post leaves me to believe that you're either lying, had a defective unit, or were just too incompetent to use the ex1/ex3.
I think you should mind your manners Pete, the mans entitled to his view, while you are not entitled to suggest he's an incompetent just because he doesnt share your point of view. I myself preferred the hvx200 over the EX for its look and other characteristics - others have vice versa - among either point of view have been camera/dops of great skill and credibility. I would be disgusted to find myself acting so arrogantly as to suggest that somebody might be incompetent just because they don't like myyy luvvie duvvie camera.
You owe the man an apology in my book - agree to disagree. Likewise you too Steve Showler hehe should try to lend a man the benefit of the doubt for his camera preference before condescending him as a mere noob for his sake of choice.
Sony are "lying attacking liars"? Wouldn't a lying liar essentially be telling the truth? :^D
And lawriejaffa, did you read that guy's post? He said, "I shot a music video on the EX1 and with the band members fast head movements, the pixels shifted and blurred together so much that you could only see a solid peach color tone where the face was supposed to be, with a couple blobs of other color intertwined."
Obviously if merely 'moving heads' in a frame blur together there's something going on unrelated to the EX1. I mean, c'mon, rolling sutter be damned but it doesn't make moving heads blur in a solid peach color tone if the settings are correct. Maybe he had a VERY slow shutter speed in low light? I can spaz like the Tazmanian Devil in front of my EX1 and it won't turn me into a color blob if I'm shooting it correctly. Music videos are shot all the time on the EX1 with band members moving their heads! :) I think something was wrong in the set up, ya think? I can shoot a flopping trout clear as a bell. I sincerely think he had something going on unrelated to CMOS.
Its funny how the same people constantly bringing up the cmos/rolling shutter issue with Sony's Ex 1/3 are now silent when the 300 was announced. All of sudden it wasnt such a big issue anymore.
acoelho1, I totally agree. It was inevitable because CMOS is where the thrust of new technology is heading so we knew this day was coming for Panasonic's "Broadcast" division.
With all due respect to Jan, in another thread she said about their CMOS chip camera showing bad skew, "The swishing back and forth of course never happens in real life, a pan happens in real shooting."
It just seems we've gone from "CMOS is unacceptable to use for serious work" to "of course swishing back and forth of course never happens in real life, a pan happens in real shooting", in defense of the Panasonic CMOS camera.
In a chip generation or two these will probably be non-issues anyway. I understand how brand loyalties work, no biggie.
